Map Feature service is running slow
3723
5
02-08-2016 09:59 PM
SibghatUllah1
I have a feature service containing more than 200 thousand customers.i have made a web mapping application to create/edit customers data , but the thing is my customer feature service is taking too much time to load.My server specification are Intel Xeon  E5620 GHz and installed ram is 32 Gb.I am using Arcgis desktop and server 10.3 with oracle. Please suggest me how can i optimize my feature service to run fast.
JakeSkinner
Esri Esteemed Contributor
Hi Sibghat,
It's recommended to have only 1,000 - 2,000 features returned by the server for a service.  This threshold will provide the best performance.  You can also set up scale dependencies.  For example, you could set the service to only be visible at large scales (i.e. > 1:9,000).  Another option, if the data does not change often, is to create a tiled service layer to accompany your feature service.  You can use the tiled service to display at small scales, and as you zoom in to larger scales you then use the feature service.
One questions, are you currently working with an ArcGIS Online Hosted Feature Service or an ArcGIS Server Feature Service?
http://support.esri.com/fr/knowledgebase/techarticles/detail/44060
SibghatUllah1
Hi Jake,
I am using Arcgis server feature service.My data needs to be updated from different survey teams, so i can not go for tile map service.
JakeSkinner
Is the REST URL available exernally?  If so, can you share it?
SibghatUllah1
No it is not.
SibghatUllah1
Dear Jake,
one thing i forget to mention is that my features layer has related tables.Is this the one of the reason it is slow??
