How to get distance and azimuth between points with qml?
3832
02-08-2016 02:40 AM
ThomasDobrzinski
I am totally new in developing apps with the AppStudio and qml, so hopefully the questionis not too easy.
I want to calculate the distance and the azimuth (bearing) from my current (gps)-position to a point on the map.
What i already did:
I added a positionDisplay to my map.
positionDisplay {
                       compass: Compass {
                           active: true
                           // Create a variable to hold azimuth
                           property double azimuth: 0
                           // Change sensor axis depending on 'userOrientation' property
                           axesOrientationMode: Compass.UserOrientation
                           onReadingChanged: {
                               // Called when a new compass reading is available
                               compass.azimuth = reading.azimuth;
                              //Or better Call it when Reading is available?
                              //geoResult = locationPoint.geodesicDistance(toPoint);
                       positionSource: PositionSource {
                           active: true
                           onPositionChanged: {
                               locationPoint.valid = position.longitudeValid && position.latitudeValid
                               locationPoint.x = position.coordinate.longitude;
                               locationPoint.y = position.coordinate.latitude;
                               locationPointChanged();
The points are set like this
   property Point locationPoint : Point {
                property bool valid : false
                spatialReference: SpatialReference {
                    wkid: 4326
            property Location toPoint :Location{
                coordinate {
                    latitude: 55.314835
                    longitude: 8.458156
I thought I could use the GeodesicDistanceResult to get distance and azimuth, but it didn't worked.
GeodesicDistanceResult{
like in my "onPositionChanged"
so what's wrong or how do i have to use it?
Thanks in advance!
Thomas
Tags (3)
LucasDanzinger
Esri Frequent Contributor
Maybe this will help get you on the right track - RuntimeQtSamples/main.qml at master · ldanzinger/RuntimeQtSamples · GitHub
