Aggregating sections within large polygon subdivisions
1665
02-05-2016 09:52 AM
LarryGaudieri
Not sure I even worded that right...what I need to do is list (or summarize) the sections, townships and ranges covered by large subdivisions. Some are small and won't span a whole section, others are large enough to fall across multiple sections (and even a township or range depending where they lie).
I need to be able to create a table or a feature class (using the subdivision & sections feature classes) that will list the sections, townships and ranges for each subdivision name. Can someone help me? All thanks for any directions.
DanPatterson_Retired
LarryGaudieri
Jaynata & Dan....thanks guys. I ultimately used the spatial join....my early attempts at using it were backwards and I got confused. I needed to target sections with the join layer being subdivisions. Appreciate the fast responses.
JayantaPoddar
MVP Esteemed Contributor
