ArcGIS server javascript coding help
5424
02-04-2016 07:51 AM
Muqit_Zoarder
Hello All, i need a programming related help. I am working on development of a ArcGIS server based web application. I can now see my layer and the layer list but i want to see the pop-up info box of the feature (on click event). I tried with the coding from ArcGIS Javascript API sites. But something is going worng here. Please see my coding. Also I could not add the base mapGallery.
<!DOCTYPE html>
<html>
<head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <meta http-equiv="X-UA-Compatible" content="IE=Edge" />
        <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
        <title>Dresden Building Web Map</title>
        <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
        <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #ins {
        background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 200px;
         right: 30px;
         margin: 5px;
         padding: 10px;
         top: 0px;
         width: 300px;
         z-index: 40;
        h2 {
                text-align: center;
                margin: 4px 0;
      h3 {
         margin: 0 0 5px 0;
         border-bottom: 1px solid #444;
      .shadow {
         box-shadow: 0 0 5px #888;
      #map {
         margin: 0;
         padding: 0;
      #feedback {
         background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 300px;
         left: 25px;
         margin: 5px;
         padding: 10px;
         top: 170px;
         width: 300px;
         z-index: 40;
      #note,
      #hint {
         font-size: 80%;
      #note {
         font-weight: 700;
         padding: 0 0 10px 0;
      #layerList {
         width: 200px;
      .dojoDndItemOver {
         background: #ccc;
      #search {
                display: block;
                position: absolute;
                z-index: 2;
                top: 100px;
                left: 25px;
   </style>
   <script type="text/javascript">
            dojoConfig = {
                parseOnLoad: true,
                isDebug: true
        </script>
   <script src="https://js.arcgis.com/3.13/"></script>
      // the infos object is used to track layer visibility and position
      var map, buildLayer, infos = {};
      require([
      "esri/map",
      "esri/layers/ArcGISDynamicMapServiceLayer",
      "esri/dijit/Search",
      "esri/tasks/IdentifyParameters",
      "esri/tasks/IdentifyTask",
      "esri/InfoTemplate",
      "esri/layers/DynamicLayerInfo",
      "esri/layers/LayerDataSource",
      "esri/layers/LayerDrawingOptions",
      "esri/layers/TableDataSource",
      "esri/Color",
      "esri/renderers/SimpleRenderer",
      "esri/symbols/SimpleFillSymbol",
      "esri/symbols/SimpleLineSymbol",
      "dojo/dom",
      "dojo/dom-construct",
      "dojo/dom-style",
      "dojo/query",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/dnd/Source",
      "dijit/registry",
      "dijit/form/Button",
      "dojo/domReady!"
    ], function (
         Map, ArcGISDynamicMapServiceLayer, Search,
         DynamicLayerInfo, LayerDataSource,
         LayerDrawingOptions, TableDataSource,
         Color, SimpleRenderer, IdentifyParameters, IdentifyTask, InfoTemplate,
         SimpleFillSymbol, SimpleLineSymbol,
         dom, domConstruct, domStyle,
         query, on,
         parser, arrayUtils, Source, registry
         parser.parse();
         var dynamicLayerInfos;
         map = new Map("map", {
            basemap: "topo",
            center: [13.7383200, 51.0508900],
            zoom: 13,
            slider: true
         }), search = new Search({
                    map: map
                    }, "search");
                    search.startup();
        var dndSource = new Source("layerList");
         dndSource.on("DndDrop", reorderLayers);
         buildLayer = new ArcGISDynamicMapServiceLayer("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer/");
         buildLayer.on("load", function (e) {
            dynamicLayerInfos = e.target.createDynamicLayerInfosFromLayerInfos();
            arrayUtils.forEach(dynamicLayerInfos, function (info) {
               var i = {
                  position: info.id
               if (arrayUtils.indexOf(buildLayer.visibleLayers, info.id) > -1) {
                  i.visible = true;
               } else {
                  i.visible = false;
               infos[info.id] = i;
            infos.total = dynamicLayerInfos.length;
            e.target.setDynamicLayerInfos(dynamicLayerInfos, true);
         // only create the layer list the first time update-end fires
         on.once(buildLayer, "update-end", buildLayerList);
         // hide the loading icon when the dynamic layer finishes updating
         buildLayer.on("update-end", hideLoading);
         map.addLayer(buildLayer);
        function buildLayerList() {
            dndSource.clearItems();
            domConstruct.empty(dom.byId("layerList"));
            var layerNames = [];
            for (var info in infos) {
               if (!infos[info].hasOwnProperty("id")) {
                  continue;
               // only want the layer's name, don't need the db name and owner name
               var nameParts = infos[info].name.split(".");
               var layerName = nameParts[nameParts.length - 1];
               var layerDiv = createToggle(layerName, infos[info].visible);
               layerNames[infos[info].position] = layerDiv;
            dndSource.insertNodes(false, layerNames);
         function toggleLayer(e) {
            showLoading();
               var i = infos[info];
               if (i.name === e.target.name) {
                  i.visible = !i.visible;
            var visible = getVisibleLayers();
            if (visible.length === 0) {
               buildLayer.setVisibleLayers([-1]);
            } else {
               buildLayer.setDynamicLayerInfos(visible);
         function reorderLayers() {
            showLoading();
            var newOrder = getVisibleLayers();
            buildLayer.setDynamicLayerInfos(newOrder);
         function getVisibleLayers() {
            // get layer name nodes, build an array corresponding to new layer order
            var layerOrder = [];
            query("#layerList .dojoDndItem label").forEach(function (n, idx) {
                  if (i.name === n.innerHTML) {
                     layerOrder[idx] = i.id;
                     // keep track of a layer's position in the layer list
                     i.position = idx;
                     break;
            // find the layer IDs for visible layer
            var ids = arrayUtils.filter(layerOrder, function (l) {
               return infos.visible;
            // get the dynamicLayerInfos for visible layers
            var visible = arrayUtils.map(ids, function (id) {
               return dynamicLayerInfos[id];
            return visible;
         function createToggle(name, visible) {
            var div = domConstruct.create("div");
            var layerVis = domConstruct.create("input", {
               checked: visible,
               type: "checkbox"
            }, div);
            on(layerVis, "click", toggleLayer);
            var layerSpan = domConstruct.create("label", {
               for: name,
               innerHTML: name
            }, div);
            return div;
         function showLoading() {
            domStyle.set(dom.byId("loading"), "display", "inline-block");
         function hideLoading() {
            domStyle.set(dom.byId("loading"), "display", "none");
             var iTask = new IdentifyTask(buildLayer);
                function onIdentifyComplete (results) {
                    return arrayUtils.map(results, function (result) {
                        var feature = result.feature,
                            title = result.layerName,
                            content;
                        switch(title) {
                            case "gis.osm_buildings_v06":
                                content = "${*}"; //"OSMID: ${osm_id}<br />CODE: ${code}<br />TYPE: ${type}";
                                break;
                            /*default:
                                content = "${*}";*/
                        feature.infoTemplate = new InfoTemplate(title, content);
                        return feature;
                function onMapClick (event) {
                    var params = new IdentifyParameters(),
                        defResults;
                    params.geometry = event.mapPoint;
                    params.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
                    params.mapExtent = map.extent;
                    params.returnGeometry = true;
                    params.width = map.width;
                    params.height= map.height;
                    params.spatialReference = map.spatialReference;
                    params.tolerance = 3;
                    defResults = iTask.execute(params).addCallback(onIdentifyComplete);
                    map.infoWindow.setFeatures([defResults]);
                    map.infoWindow.show(event.mapPoint);
                function onMapLoad() {
                    map.on("click", onMapClick);
                if (map.loaded) {
                    onMapLoad();
                } else {
                    map.on("load", onMapLoad);
   </script>
</head>
<body class="claro">
   <div style="width: 100%; height: 100%; margin: 0;">
        <div id="map">
            <div id="search"></div>
            <div id="ins" class="shadow">
                    <h2>BUILDING INFORMATION WEB MAPPING OF DRESDEN </h2>
                    <p>Click on the map to view the building information data of Dresden. This is based on open source data.</p>
            </div>
            <div id="feedback" class="shadow">
                <h3>Layers</h3>
                <div id="info">
                    <div id="hint">
                        Click and drag a map layer name below to re-order layers. The first layer in the list will be drawn on top.
                    </div>
                    <strong>Map Layers</strong>
                    <img id="loading" src="https://dl.dropboxusercontent.com/u/2654618/loading_black.gif">
                    <br>
                    <div id="layerList"></div>
                </div>
            </div>
        </div>
    </div>
</body>
</html>
so far result is
Tags (1)
RobertScheitlin__GISP
Muqit,
  Here are the issues I see:
  The most common mistake by JS API beginners is that your requires and their subsequent matching vars are out of order:
require([
      "esri/map",
      "esri/Color",
      "dojo/dom",
      "dojo/dom-style",
      "dojo/query",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/dnd/Source",
      "dijit/registry",
      "dojo/domReady!"
    ], function (
      Color, SimpleRenderer, SimpleFillSymbol, SimpleLineSymbol,
      query, on,
You are try to construct an IdentifyTask using a layer and not a string that represents a url.
var iTask = new IdentifyTask("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer/");
Muqit_Zoarder
Robert,
I tried with
but its not working.
Muqit,
   DId you also make the require code block change I outlined?
PanagiotisPapadopoulos
try to construct the map using webmap (by ID or JSON) (e.g. Web map by ID | ArcGIS API for JavaScript ).
The Pop -up functionality embedded and  managed from webmap and is the easiest way to create , update and manage your custom application content.
