arcpy.TableToTable_conversion CSV to DBF help
9518
12
02-03-2016 01:19 PM
DannyLackey
Using this page as my resource: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
I came up with this:
import arcpy
from arcpy import env
env.workspace = "C:\"
inTable = "c:\test.csv"
outLocation = "c:\test.dbf"
outTable = "test"
arcpy.TableToTable_conversion(inTable, outLocation, outTable)
However, it's failing:
  File "c:\test.py", line 4, in <module>
    arcpy.TableToTable_conversion("c:\test.csv", "c:\test.dbf", "test")
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\conversion.py", line 1904, in TableToTable
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset c:\test.csv does not exist or is not supported
ERROR 000732: Output Location: Dataset c:\test.dbf does not exist or is not supported
Failed to execute (TableToTable).
Is it clear where I'm going wrong?
Tags (3)
DarrenWiens2
Your paths are wrong, for Python. '\t' happens to mean tab. You can get around it by always prefacing paths with an 'r' to denote raw string format.
For example:
inTable = r"c:\test.csv"
DarrenWiens2
For example:
DannyLackey
Thank you.  I got it working.  I had a few things wrong.
Here is my new WORKING code:
import arcpy
env.workspace = r"C:\test"
inTable = r"C:\test\test.csv"
outLocation = r"C:\test\output"
outTable = "test.dbf"
AdrianWelsh
MVP Honored Contributor
Can't you also use double backslash in place of the regular backslash in order to make the path correct?
inTable = "c:\\test.csv"
Luke_Pinner
MVP Regular Contributor
  1. inTable = "c:\\test.csv"
Yes. And forward slashes work as well:
inTable = "c:/test.csv"
AdrianWelsh
I was going to mention that too! You beat me to it!
DarrenWiens2
Yes, but double backslashes are more typing. As Luke points out, you can also use forward slash, but then you need to remember whether it's forward or backslashes you can't use. It's personal preference, but I use 'r'.
Luke_Pinner
I tend to use r'' as well. Except when it doesn't work.
DarrenWiens2
Good to know. I can't say I've ever run into that situation (e.g. r'\'), but the lengthy and pointed discussion certainly makes me think it comes up more often than my brief experience.
Luke_Pinner
It's not just r'\', but any trailing backslash, i.e r'C:\'
