Issue with Python and data driven pages
2239
02-01-2016 09:32 PM
AnthonyCheesman1
Less of a question, more of a bug report.
I've been trying to export a map series using Python and DDP. The issue arises when I try and set map resolution when calling ddp.exportToPDF
I'm using ArcGIS 10.2.2 and Python 2.7.5 64 bit. I've tried running this from IDLE command line, IDLE interpreter, and PythonWin interpreter
This works:
>>> mxd = arcpy.mapping.MapDocument(r"D:\FOP1518\HPBR1516-11_FOP1516_Hume_Availability\mxd\fop_availability_layout_ddp.mxd")
>>> ddp = mxd.dataDrivenPages
>>> ddp.exportToPDF(r"D:\FOP1518\HPBR1516-11_FOP1516_Hume_Availability\output\Murrindindi\BurnAvailability_Murrindindi_","ALL","","PDF_MULTIPLE_FILES_PAGE_NAME")
But when I try and set output resolution to 250dpi, the interpreter crashes
ddp.exportToPDF(r"D:\FOP1518\HPBR1516-11_FOP1516_Hume_Availability\output\mur_test\BurnAvailability_Murrindindi_","ALL","","PDF_MULTIPLE_FILES_PAGE_NAME",250)
Has anyone else experienced this? Am I doing something blindingly obviously wrong?
Anthony
Tags (3)
