python scripts doesn't execute in arcgis 10 ????
3275
02-02-2016 10:08 AM
sanabelja
hi
can any one guided me please !!
i start to learn arcpy with arcgis ... writing scripts on python window in arcgis 10 !! but it doesn't execute any one of them ??????
Tags (1)
DanPatterson_Retired
try
>>> import arcpy
at the command prompt (ie the >>> in your IDE)
any luck?
sanabelja
thank you sir
but it's not given me error when import arcpy !! and arcpy.mapping !! but when i complete the script it doesnt execute ?!!..even the function comletion dont recognize the method so !!!!!!
show the script... perhaps there are no print or arcpy.AddMessage lines to show the output information
RebeccaStrauch__GISP
It would help if you code post your code using Posting Code blocks in the new GeoNet​
If we can have a look at it we should be able to see if it is a coding issue.  If not, then the next things would be to see if there is a problem with your installation and finding python.
Also, have you tried running the code in the Python window in ArcMap/Catalog?  are you getting any errors there?
