Calling SQL ST_GEOMETRY function with Oracle RAC hangs
3312
02-01-2016 10:02 PM
ModyBuchbinder
Hello all
We installed ArcSDE on Oracle11g with RAC on Linux.
If we try to use any ST_GEOMETRY function for SQL (for example ST_BUFFER) it just hangs.
It is working fine without the RAC.
If we change the library name (for checking) we get an error in the SQL (library not found) so I think the library is defined fine.
Anybody have a clue?
VinceAngelo
Esri Esteemed Contributor
You've left out important details from your  problem statement:
  • Which mechanism did you use to configure the instance with the libst_shapelib.so DLL?
  • Is the full path to that library present on each node in the cluster?
- V
ModyBuchbinder
Hi V
Sorry for the delay.
Oracle is running on Linux. The library was copied to both machines and the listner was updated.
The path is absolute.
As I wrote, if we change the library name on disk we get error message that the file does not exists.
I think it prove that the installation is fine.
Any idea?
VinceAngelo
If you've altered the Listener, you probably used the wrong procedure.  Since 11gR2, the correct library registration procedure involves the hs/extproc.ora file.
- V
