Using Increments
2862
02-01-2016 08:09 AM
JonathanMcDougall
In Arc 9.2 I was able to use the following script to calculate incremental numbers;
Static rec As Long
Dim lStart As Long
Dim lInterval As Long
Dim i As Integer
Dim iStringLength As Integer
Dim sID As String
'set the variables below
iStringLength = 7
lStart = 0001
lInterval = 1
sID = ""
If (rec = 0) Then
rec = lStart
Else
rec = rec + lInterval
End If
For i = 1 To iStringLength - Len(CStr(rec))
sID = sID & "0"
Next i
sID = sID & CStr(rec)
In Arc 10.2, am I right in saying that I can no longer use this script? I've tried the posted python example of;
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
  rec = pStart
else:
  rec = rec + pInterval
return rec
This is fine, to a degree but not the results I'm truly looking for.
I'm looking to populate a 4 character field with leading zeros as well as incrementing by 10 each new record.
eg; 0010, 0020, 0030, etc up to a possible 9990.
Anyone able to help?
Thank you.
Tags (1)
XanderBakker
Esri Esteemed Contributor
Try this:
rec=0
    global rec
    pStart = 10 #adjust start value, if req'd
    pInterval = 10
    if (rec == 0):
        rec = pStart
    else:
    return "{0}".format(rec).zfill(4)
XanderBakker
Try this:
rec=0
    global rec
    pInterval = 10
    if (rec == 0):
        rec = pStart
    else:
