attribute alias
3627
5
01-28-2016 04:36 AM
mikeatkinson
Trying to use the Edit widget in a Web Map App built through Builder.
Data is a zipped shapefile of attributed polygons uploaded to ArcGIS Online from which a Feaure Service has been created.
I can configure the Pop Up box to include attributes - with alternative (Alias) names manually in the configuration box. Interrogating features - the popup displays correctly. (Pic 1)
When however I open the Edit Widget - this displays fields with the Attribute Field names defined in the Feature Service.
Using the "Configure Attributes" tool - I can rename the Alias fields - (and turn off fields I don't need editors to see) however the changed Alias names are not displayed to users in the Editor Pop Up window - which defaults to the Feature Service names (Pic 2)
Am I missing something obvious......
AdrianWelsh
MVP Honored Contributor
Can you post a screenshot of the Edit widget configuration dialog that you're using so we can see what you see?
mikeatkinson
This is the configuration screen. Example is I wish to have the Field Alias Information_1 rather than NOTES_2 (which is the attribute field name) - This isn't coming through into the Editor window though.
AdrianWelsh
hmmm, is there a way for you to share a screenshot of the Edit widget configuration to see if there is some kind of option there that needs to be looked at?
mikeatkinson
Well - will you look at that.
I thought I had clicked everywhere possible but it turns out a double click on the Alias field in this configuration window allows you to Edit the Alias name field (it isn't obvious that that option is there....)
Renamed as required - re- saved the App - refreshed and......
..........all working.
I obviously just needed to ask someone 😉
Many thanks
AdrianWelsh
Great! Glad to know it is working for you.
