eSearch issue with spatial search
1245
01-28-2016 11:47 AM
JamesCrandall
I'm experiencing a new problem with the eSearch widget that I just installed that is related to running a spatial search on another service layer from the currently selected feature in another service layer.
Everything appears to work correctly in that I am able to perform the select by value on the initial Search Layer.  However, in the By Spatial search dialog it correctly lists the "Search entities of:" values in the drop-down to include the second layer.  What happens is that when I click the "intersected by" it selects coincident features from the first layer where the first selection is made!
This wasn't an issue in previous versions from what I remember and I only noticed this recently when doing some testing.
Any suggestions on what to do or where to look to see if something is not getting updated when I make any settings changes?
Thanks!
Tags (1)
RobertScheitlin__GISP
James,
   Sorry this is a new issue in 1.3 I broke something unintentionally.
Here is a thread that provides the code fix workaround until 1.3.0.2 comes out:
https://community.esri.com/docs/DOC-1731#comment-20581
James,
JamesCrandall
Edit: I was able to fix per your suggestion.
YESSSS!
Whew... thanks Robert.  I was really hoping to see this and will get to the workaround asap.
THANK YOU!
