eSearch widget console error
2689
6
01-26-2016 09:48 AM
RudoDuncan
Robert Scheitlin, GISP
I was wondering if this error looked familiar to you. When doing my search everything worked fine but when I looked in my console there 997 errors. Do you have any suggestion on a fix for this?
RobertScheitlin__GISP
Rudo,
   Make sure that your config_Enhanced Search.json has this for the picturemarkersymbol:
"symbols": {
    "simplemarkersymbol": null,
    "picturemarkersymbol": {
      "url": "images/i_search.png",
      "height": "20",
      "width": "20",
      "type": "esriPMS",
      "angle": "0"
Rudo,
   Never seen that one before. what are you doing when you get these errors?
RudoDuncan
If I query only by Start/End date I get this error when I look at the console.
When I add Radio and Beat with Start/End date I get this warning.
Rudo,
   The warning is normal (nothing to worry about). The errors look like they are coming from the graphic results of the search. Do you have null geometry in your data?
RudoDuncan
I think you're right, when I change the symbology (from defaults) it is suppose to show green and blue triangles based off of the call category(dispatched & self initiated) field in this layer.
But the results are as followed... Is this something that is easily fixed?
Rudo,
"symbols": {
      "height": "20",
      "width": "20",
      "type": "esriPMS",
      "angle": "0"
RudoDuncan
OK, thanks again. I will download and test it.
