Not All Records are Publishing to ArcGIS Online
11226
26
01-21-2016 11:13 AM
MichaelTorbett1
I am trying to publish a feature from a file geodatabase to ArcGIS online. This feature contains 611 records, however when I publish it to my organizations online account, only 510 records appear. I don't understand, the maximum records allowed is set to 1000 in the publishing window. Everything seems to be in working order and I recently published a similar layer containing almost 3000 records with no problem. Any insight to what might be causing this problem would be greatly appreciated.
Thanks and have a great day!
Michael
Tags (1)
KyleBalke__GISP
Try running the Check Geometry geoprocessing tool and then Repair Geometry if there are errors (ensure you make a backup of your data before running the repair).
MichaelTorbett1
I went ahead and did the check, which found a few errors. Created a duplicate feature (and geodatabase) and ran the Repair Geometry tool. unfortunately I'm still having the same problem. The rest of the features appear to be correct in geometry and I can't find anything within the attributes that's preventing these 101 features from publishing.
Thank you for the suggestion Kyle.
KyleBalke__GISP
What method are you using to publish?  Via ArcMap or Add Item in ArcGIS Online?
MichaelTorbett1
I'm publishing through ArcMap.
CathyWilson
I'm having the same problem. I have a very simple point layer in an ArcGIS Map. I'm Publishing it as a Service and when I look at it online, I'm missing a lot of records. I'm working with under a 1,000 records and I tried using a Definition query to include only the records I really need. On my latest test, 15 out of 51 records were uploaded. One test was with about 67 records and 31 uploaded. The whole feature class only has 177 records, so the 1,000 record limit should not be coming into play.
Then I tried Adding the layer from AGOL (Thank you Kyle for the idea.) and was able to upload all 177 records. (It required exporting the feature from the gdb, then zipping it, but it worked.) So something to do with the ArcMap Publisher, then? At least I now have a work around.
CathyWilson
Of course, now I have to re-do my nice symbology online.
KyleBalke__GISP
Cathy...if you can feel free to send me the problem feature class and I can try to troubleshoot for you.
CathyWilson
I'll send it in a couple of days. I'm out of town now to teach some summer volunteers to collect data with ArcPad.
Thank you,
Cathy
Sent from my iPhone
KellyGerrow
Esri Alum
Hi Cathy,
Try contacting Technical Support. They can help troubleshoot the issue and find out what is causing the problem.
-Kelly
