Custom Theme
3020
01-19-2016 01:43 PM
VIKRANTKRISHNA
Starting from Demo Theme, If I want to add a panel that looks similar to LanuchPad Theme panel, What would be the best way to do. Can I just copy the panel from Launchpad Theme, add it to the Demo Theme, and add it in the theme template config file?
JordanBaumgardner
That is exactly what our UI guys did to start playing around with custom templates.
VIKRANTKRISHNA
Did that worked, doesn't seems to be working for me. The header panel works, but Left floating panel is not working.
JianWang2
It may not work if you simply copy and paste launchpad theme panel. You should design the UI and implement the logic. The launchpad theme panel can be a good reference.
