I am very new to Python but need to write a script to add 20% to a field and then round that number with the 20% to the next 50. I have figured out the calculations but for the life of me can't figure out how to put them together to get it into one function.
I've tried this in the code block:
def boom_length(boom): twenty_percent = ((!LENGTH_FT!) * 0.2) + !LENGTH_FT!) math.ceil(twenty_percent + (50 - twenty_percent) % 50) return twenty_percent
then in the expression:
boom_length(!BOOM_LEN!)
Thanks in advance for the help!
Solved! Go to Solution.
...and to explain the reason for these changes:
return math.ceil(twenty_percent + (50 - twenty_percent) % 50)
I'm no python expert by any means but have you looked at the round() method?
http://stackoverflow.com/questions/17470883/how-to-round-to-two-decimal-places-in-python-2-7
Try this:
def boom_length(boom): import math twenty_percent = boom * 0.2 + boom twenty_percent = math.ceil(twenty_percent + (50 - twenty_percent) % 50) return twenty_percent
I think this is on the right track but it does not pull the value to add 20% to from the field "LENGTH_FT". My mistake...I should have mentioned that in the original post. I need it to pull a value from the field "LENGTH_FT", add 20% to it, then round that number up to the nearest 50 and store it in the field "BOOM_LEN"
Assign the ouput to the field !BOOM_LEN!, but use the field !LENGTH_FT! as parameter in the expression:
in the expression:
boom_length(!LENGTH_FT!)
Thanks for the help! I was thinking too much about it...simple solution.
