Custom Widget
2463
01-18-2016 09:45 AM
SalvatoreScimeca
Hello All,
I created a custom widget that changes the renderer of a feature layer.  The new feature layer is drawn over the original, and now they are slightly off.  What could be the cause of this?  I have attached a screenshot for reference.  Any help is greatly appreciated.
Thank you,
Salvatore
RebeccaStrauch__GISP
From the image, I'm not sure which symbols you are saying are off (that us, what is original and what is newly rendered?). I  any case, it may be a projection or spatial reference issue.  Are you using a custom or non-Web Mercator Aux (the default ArcGIS Online) coordinate system?  If so, you may need to specify your wkid for the rendered Layer...may be defaulting to the WMA.  That is just a guess.
it would probably help others to debug if they could see the code in question.
SalvatoreScimeca
The original Symbols are in orange, and the new ones are the other colours.  For the coordinate system, I am using
  • NAD_1983_StatePlane_New_York_Long_Island_FIPS_3104_Feet
