LaunchPad Theme HTML Layout Issues
2414
01-14-2016 03:51 AM
AnthonyGiles
Honored Contributor
Hi All,
I am having issues with trying to layout HTML elements in a widget when using the LaunchPad Theme. I have a very simple widget layout at the moment with just a label, a measurement dijit, and a piece of text below. Here is the widget.html
<div>
    <div><label>${nls.descriptionlabel}</label></div>
    <div data-dojo-attach-point="_measureNode"></div>
    <div>Press <b>CTRL</b> to enable snapping.</div>
</div>
This displays as expected in every theme except the launchpad theme where I cannot get anything to appear below the measurement dijit:
Foldable Theme:
Billboard Theme:
Box Theme:
Dart Theme:
LaunchPad Theme:
I suspect it is something to do with the LaunchpadPanel but I cannot for the life of me work out whats going on. What do I need to do to display HTML elements below the measurement dijit
Any help would be appreciated
Regards
Anthony
RobertScheitlin__GISP
Anthony,
   The issue is that the launchpad theme has some css overrides that position the measurement dijit using absolute values of 0 for top, bottom, left and right:
.claro .esriMeasurement {
  position: absolute;
  left: 0;
  right: 0;
  top: 0;
So you will have to override those with !important in your css for positioning your div.
Or you can just comment out the above code block from the launchpad.css in the
[install dir]\client\stemapp\themes\LaunchpadTheme\styles\default\css
folder or your apps
[install dir]\server\apps\[app #]\themes\LaunchpadTheme\styles\default\css folder
Anthony,
  position: absolute;
  left: 0;
  right: 0;
  top: 0;
folder or your apps
AnthonyGiles
Honored Contributor
Cheers Robert,
Timely and correct as usual.
I added the following into the widgets style.css and it has sorted it out:
.LaunchpadTheme .esriMeasurement {
  position: inherit !important;
Regards
Anthony
