External_choices error when convert to XLSForm
3243
5
01-13-2016 08:48 AM
Juan_JoséPino_Povedano
Hi!!
I´m trying to use the external choices with Survey 1.2.12, when the app is converting to XLS Form, the application shows this error:
I don´t know why this error happens, I´ve created the external_choices:
I ´ve created the select_one_external in survey and the relation with Provincia in the choice_filter
${Provincia}=Provincia
Does anyone know what It happens?
Thanks a lot,
JJ Pino.
FasilTiru
Juan,
We reviewed your XLSFile and discovered the source of the error. It looks like the validation is failing due to the nonASCII characters in the label column of external_choices sheet. The Survey123 team will review this issue and provide a solution soon.
Fasil T.
Esri Support
MikeMillerGIS
Esri Frequent Contributor
This forum is for the utility configurations, for general help, I would suggest posting in Survey123 for ArcGIS
IsmaelChivite
Esri Notable Contributor
could you please share the XLSFile with us so we can have a look?  You can upload files in GeoNet.
Ismael
I haven´t got permission to upload files, I send you a Link from wetransfer to download the XLSFile.
http://we.tl/64mm3Rmfj6
Best regards,
JJ Pino.
FasilTiru
Juan,
Fasil T.
Esri Support
Ok, I´ll try to no use that kind of characters.
JJ Pino.
