Re: Is there a way to change the column names in the attribute table for the search results of the enhanced search widget?
3036
13
01-12-2016 07:25 AM
RudoDuncan
Sorry, is there a way to make one of the fields in the pop up a hyperlink?
RobertScheitlin__GISP
Rudo,
   Sure look at this stop in the Help documentation:
Web AppBuilder for ArcGIS | Help - Enhanced Search widget | Links
AravindStoryMaps
Hi Robert,
is there a table of contents to your help documentation, so we can move through all of the custom widgets?
Aravind
Aravind,
   Not sure I completely understand the question. Are you asking if I have an overall landing page that lists the links to all my different widgets help pages?
AravindStoryMaps
Yes. That's better articulated.
Aravind,
   Currently no. But this would not take much to do, thanks for the idea.
AravindStoryMaps
Thank you for the consideration, Robert. The help documents are really useful. Especially to people like me who are just starting to configure and create custom widgets.
Aravind
Aravind,
   Just in case you did not know. When you are configuring my custom widgets the link on the main configuration page called "Learn more about this widget" will take you to my help doc for that widget.
MichaelRobb
Honored Contributor
Hi, sort of confusing question title vs questio.
Your Question:
Yes there is... in the Web Map on the layer desired >> left click >> Configure Pop-Up
Choose the A Custom Attribute Display
Then click on the Green button 'Configure'
This is a simple HTML editor..
There is a button in which you can create the HYPERLINK... and concagnate any field value as well as passing parameters.
Your popup would then have that Hyperlink
enjoy!
Michael,
   It is a little confusing but as you can see in the title, it is a question about the Enhanced Search Widget.
