Newb Question : URL to Feature Class?
2550
01-11-2016 12:57 PM
BrianO_keefe
Honored Contributor
I have a question that is probably stupid.
In an SDE environment can you craft a URL that points directly to a Feature Class within an SDE GDB?
For instance... Servername XYZ, Feature Dataset ABC, FeatureClass Widget
Could I craft a URL (for internal usage only) that would point to the Widget Feature Class?
I'm trying to put together live (wiki-esque) documentation and I'm wondering if this is possible.
JoeBorgione
Why not point to a ArcGIS server app?  That's what I've done in our internal wiki.
JordanBaumgardner
The short answer is yes. You can publish an MXD with your feature class to an ArcGis server and it will have a url that will serve up that feature class. It will also allow editing and updating if you wish. Publish features—ArcGIS Online Help | ArcGIS
