Hello
4385
7
01-05-2016 01:46 PM
AnnSolano
My name is Ann Solano.
I was allowed on a computer that has ArcGIS. So I sign in and attempt to begin the virtual training campus. I begin with Learning ArcGIS Desktop(for ArcGIS 10.0). My problem is when I hit Step 3 on Download the data file. I click Download file for Step 1. On my Step 2 there isn’t any Save option there is only Open which in opens up a popup box that is titled Open File- Security Warning. Then inside the box it says Publisher couldnot be verified Are you sure you want to run this software? The instructions in 3. Download the data file 2. Says not to open file or run, The Save Dialog doesn’t display. I am a bit frustrated because there is nothing in the files save on Desktop or Downloads. I am also not getting any closer to my first intention on GIS training.
deleted-user-08X689byEKuE
What web browser are you using when you download the file? Chrome, Firefox, Internet Explorer, other?
AnnSolano
Chrome
In Chrome, there should be three horizontal lines in the top right of the window (in the menu bar). Click that, then you should see an option that says "Downloads".. Click that. It will open a window showing your downloads; in the top right of that window (below the menu bar) you should see "Open downloads folder". Click that and a Windows Explorer window will open to where your file was downloaded. That is where it is saved.
I hope this helps,
Keely
AnnSolano
I was using Chrome but didn't have access
Thanks for the update. That's definitely a roadblock I hope it all goes much smoother after you get access to the files.
AnnSolano
Thank you for the fast responses. Much appreciated!
JoaquinRoibal
Welcome to the GIS forums!
