ApplySymbologyFromLayer does not work in my python code
3275
12-27-2015 02:27 AM
MonirRahman
I have  a layer file. I make a button in ArcGIS 10 with .NET. I want to change layer symbology with the layer file. For this purpose I Write python code and execute it from C#. If the following code is written in python window of ArcGIS, then works fantastic. But from my code, it does not work. Can anyone help me ??
try
               const string prg = @"import sys
import arcpy
from arcpy import env
mxd = arcpy.mapping.MapDocument('CURRENT')
layer = arcpy.mapping.ListLayers(mxd)[0]
    arcpy.ApplySymbologyFromLayer_management(layer,'C:\Users\DELL\AppData\Local\Temp\Junctions_Temp.lyr')
               var sw = new StreamWriter("D:\\test2.py");
               sw.Write(prg); // write this program to a file
               sw.Close();
               var p = new Process
                               StartInfo =
                                       FileName = @"C:\Python26\ArcGIS10.0\python.exe",
                                       RedirectStandardOutput = true,
                                       UseShellExecute = false,
                                       Arguments = "D:\\test2.py "
                           }; // create process (i.e., the python program
               p.Start();
Thanks ...
Tags (4)
DanPatterson_Retired
your filename in applylayerfromsymbology is not pythonic, the layer location needs to be preceeded by an r to denote raw notation for paths ie r"c:\somepath\somefile" that may not be the issue, but the path to the file needs to be specified correctly
MonirRahman
Thanks Dan, for your quick reply. I have correct path format as your, but no result.
