Adding feature using x,y
2911
12-29-2015 06:50 AM
ShaziaNoreen
Hi
Does anybody know how to add a feature using x,y coordinates in Web Appbuilder?
Also I would like to add MGRS and UTM coordinate systems in measurement widget for point location.
Thanks.
RebeccaStrauch__GISP
I would look at one of these to start
Enhanced Locate Widget Version 1.3 - 12/15/2015
Location Widget
Customization of Tim W's location widget: 1.1
These assume you are using the WAB developer edition (not the AGOL version).  For other custom widgets, see Web AppBuilder Developer Edition - Customization Resource List
Location Widget
ShaziaNoreen
Hi
Thanks for replies, great widgets. But I need the other way round.Our client has asked to click on the map and get coordinates in MGRS and UTM.
Measure (or Measurement) widget provides this function in DMS and degrees only.
Thanks.
Shazia
#yiv0203903693 * #yiv0203903693 a #yiv0203903693 body {font-family:Helvetica, Arial, sans-serif;}#yiv0203903693 h1, #yiv0203903693 h2, #yiv0203903693 h3, #yiv0203903693 h4, #yiv0203903693 h5, #yiv0203903693 h6, #yiv0203903693 p, #yiv0203903693 hr {}#yiv0203903693 .yiv0203903693button td {}
GeoNet
Robert Scheitlin, GISP marked Rebecca Strauch, GISP's reply on Adding feature using x,y as helpful. View the full replyMarked as helpful:I would look at one of these to startEnhanced Locate Widget Version 1.3 - 12/15/2015 Location Widget Customization of Tim W's location widget: 1.1  These assume you are using the WAB developer edition (not the AGOL version).  For other custom widgets, see Web AppBuilder Developer Edition - Customization Resource List
Following Adding feature using x,y in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
RobertScheitlin__GISP
Shazia,
   You can do this using the Coordinate widget then. It allows for adding a new coordinate system by add the WKID you need and it allows for clicking on the map to get the coordinates
ShaziaNoreen
Thanks, Rebecca, this has solved our problem. It works both ways.Any help on adding feature in edit session using x,y coordinates??
RegardsShazia
