Toggle layer/s visibility
3687
12-22-2015 04:49 PM
AmitKokje2
Is there any widget/ tool available that will toggle the visibility of multiple layers? (switch on certain layers and switch off other at a same time)
Ultimately the widget will act as one click option to turned on or off a group of pre-configured layers. An equivalent of "historic aerials" options in this mapping application. http://goo.gl/KrU70O
The application and the toggle layer tools are Geocortex Essential workflows . The tools turns on the desired historic aerial image service along with the latest Aerials in a background while turning off all the other layers.
​This toggle is independent of layer visibility checked in applications layer list.
​I am a novice in AGOL custom widget development and looking for any equivalent or nearly identical widget I can reconfigure or modify.
​Thanks,
​Amit
RobertScheitlin__GISP
Amit,
   There is no such widget currently available to my knowledge. I have considered developing one but just have not had the time.
