Creating a buffer
2999
12-22-2015 07:01 AM
TravisMartin
Hello, this may be a basic question but I cannot resolve this issue.
I used an excel speadsheet populated with xy coordinates to plot points on my map and this worked out fine. I now want to place a buffer around the points and everytime I try I have gotten error messages saying "output feature class : <empty>" and "cannot open sheet1$events"
When I attempt to create the buffer I am pressing the dropdown arrow on input feature and selecting the layer I want, which then automatically populates the output feature class. I then put in the distance in and press ok.
What am I missing?
Thanks!
ChrisSmith7
Honored Contributor
Try exporting as a shapefile or gdb feature class first!
RebeccaStrauch__GISP
As Chris mentioned, you will need to make is a shape or feature class.  An event table is just a temporary view of the data.
Adding x,y coordinate data as a layer—Help | ArcGIS for Desktop
...If you want to be able to perform these <<or pretty much any task..my comment>>tasks, you can export the x,y layer to a feature class using the steps below or follow the steps above to use the Catalog window to create a feature class from an x,y table....
