Table Sorting in Attribute Table Widget
3737
5
12-15-2015 11:50 PM
MajdiTurkman1
One of the columns that I have in my table has a domain, and Attribute Table widget seems to sort that column based on its coded value not the description of the domain value.
Any idea how to make the sorting based on the description of the domain value?
Thanks.
RobertScheitlin__GISP
Madji,
   This seems like a bug. I am seeing the same.
Junshan Liu
Jianxia Song
ZeZhengLi
Majdi and Robert,
     I think this is the right behavior.
     What the database concerned is value not description.
Zezheng
MajdiTurkman1
Zezheng,
As a user, when you sort the column, you sort based on what you see, which is the description.
Domain code value is something internal.
Zezheng,
   I would have to disagree as most esri users would when you sort you are expecting the displayed value to be sorted (like in ArcMap).
ZeZhengLi
In this way, I will submit an issue to our repository and discuss with our PE.
Thanks for Majdi and Robert.
