hide a widget programmatically..
3826
12-16-2015 12:09 AM
NatashaManzuiga
Hi all,
Is it possible to hide a widget programmatically?
I want to do this without close a widget.
Naty
RobertScheitlin__GISP
Naty,
  It depends on if it is an onscreen widget or a widget in the widgetpool.
Here is the code that works for onscreen widget:
Require
'jimu/PanelManager',
PanelManager,
var pm = PanelManager.getInstance();
pm.closePanel(this.appConfig.widgetOnScreen.widgets[4]);//close the 5th widget in the config.json inside the widgetOnScreen object
//or
pm.closePanel(pm.activePanel);//close the active panel
Naty,
Require
PanelManager,
//or
ChristopherSchreiber
rscheitlin
I have been trying to close a widget when my custom widget is opened. I have used your solution above, but because the widget that I am trying to close resided in the widget pool, I have changed
to
pm.closePanel(this.appConfig.widgetPool.widgets[1]);
I keep getting an error that reads:
TypeError: panel.setState is not a function
The widget is an "In-Panel" widget.
Would you have any idea as to why I am getting this error?
Thank You!
Chris
Chris,
   What theme are you using? A screen shot would really help.
