passing the output of a tool as input to another
5019
6
12-15-2015 08:15 AM
KONPETROV
Hello I have the following code (its a bit big but very simple), and the problem I am facing is that I cannot pass the raster rcls to the Create Spatially Balanced tool, unless I add it to Table of Contents (lines 32- 42). I am building a new tool, so I don't want to interrupt the proccess by adding something to the Talbe of Contents, cracking my tool to 2 tools. The "values" and "num_pnts" variable (line 13-14) show the number of points that will be created. Thanks in advance.
import arcpy
import os
from arcpy import env
from arcpy.sa import *
#workspace = arcpy.GetParameterAsText(0)
workspace = "C:/Results/ArcMap/Visibility/Calc_View/"
# arithmos simion kai viewsheds
#value = arcpy.GetParameterAsText(1)
values = 2
num_pnts = int(values)
#height_val = arcpy.GetParameterAsText(2)
height_val = 100
height = int(height_val)
#demodel = arcpy.GetParameterAsText(3)
#demMAXResult = arcpy.GetRasterProperties_management(demodel, "MAXIMUM")
#demMAXResult = arcpy.GetRasterProperties_management(demodel, "MINIMUM")
demMAXResult = arcpy.GetRasterProperties_management("C:/Results/ArcMap/Visibility/Calc_View/tin2ras3g_1", "MAXIMUM")
demMINResult = arcpy.GetRasterProperties_management("C:/Results/ArcMap/Visibility/Calc_View/tin2ras3g_1", "MINIMUM")
demMAX = demMAXResult.getOutput(0)
demMIN = demMINResult.getOutput(0)
LIMIT = float(demMAX) - height
# Reclassify
outReclass = Reclassify("tin2ras3g_1", "Value", RemapRange([[float(demMIN),LIMIT,1],[LIMIT,demMAX,0]]), "NODATA")
outReclass.save("C:/Results/ArcMap/Visibility/Calc_View/rcls")
n = 0
for i in range(num_pnts):
    n += 1
    # Spatially Balanced Points
    inRaster = "rcls"
    outPoints = "C:/Results/ArcMap/Visibility/Calc_View/point" + str(n)
    arcpy.CreateSpatiallyBalancedPoints_ga(inRaster, 1, outPoints)
KONPETROV
Problem solved at line 40 at the variable inRaster, it must be imported the path of the reclassified raster like that:
inRaster = "C:/Results/ArcMap/Visibility/Calc_View/rcls"
I don't know why, it is the first time I am doing it, but only by that it works.
Luke_Pinner
MVP Regular Contributor
The help (ArcGIS Help (10.2, 10.2.1, and 10.2.2) ) states the 1st parameter "in_probability_raster" should be a Raster Layer or a Mosaic Layer, not a Raster Dataset.
When you add the Raster Dataset to the TOC, you create a Raster Layer which works in the tool.
Try creating a Raster Layer with the Make Raster Layer (Data Management) ​tool and pass that as the "in_probability_raster" parameter.
KONPETROV
I tried it your way but although I put again  workspace = ... and the makeRasterLayer_management("rcls", "rclsLayer, "") I get only an
Parameters are not valid. ERROR 000865: Input raster: rcls does not exist. Failed to execute (MakeRasterLayer).
The code after the reclassification can run only if I put rcls to the table of contents, something influences that but I don't know why?
NeilAyres
Here inRaster is just a string.
  •     inRaster = "rcls"
  •     outPoints = "C:/Results/ArcMap/Visibility/Calc_View/point" + str(n)
  •     arcpy.CreateSpatiallyBalancedPoints_ga(inRaster, 1, outPoints)
Why not just use your raster object outReclass.
KONPETROV
Neil I also tried to put
inRaster = "outReclass"
but with no result.
NeilAyres
Kon,
here you are assigning the variable inRaster to the string "outReclass"
Not the raster object which is outReclass.
But yes, you can save it and put the full pointer to it, as you have indicated.
KONPETROV
