Activate help link on home made widget
3163
12-14-2015 06:51 AM
MathieuVILLEMONT1
Generic web appbuilder widgets setting page displays a link to access the help.
However home made widgets do not display such link.
My solution is the following hack :
_help: '<my own help url>',
startup: function () {
     dojoQuery(".help-link").forEach(lang.hitch(this, function (node, index) {
          domStyle.set(node, "display", "inline-block");
          domAttr.set(node, "href", this._help);
Any other suggestions welcome.
Ce message a été modifié par : Mathieu VILLEMONT My initial post did not include the hack 😕
RobertScheitlin__GISP
Mathieu,
  I have discussed this with the development team last year at the Dev Summit. that custom widget developers need the ability to add help links to custom widgets. I informed them of the Hack I am having to use in all my widgets.
setConfig:function(config){
      //hack the 'Learn more about this widget link'
      setTimeout(function(){
        var helpLink = dojo.query('.help-link');
        helpLink[0].href = 'http://gis.calhouncounty.org/WAB/V1.2/widgets/eSearch/help/eSearch_Help.htm';
        html.setStyle(helpLink[0],'display','block');
      },600);
MathieuVILLEMONT1
Robert,
Indeed because the <a> is there anyway it would be nice to simply set it with a variable instead of hacking the DOM.
Nice help page btw. Did you use a template ? Markdown maybe ?
Mathieu,
   No I just took what esri had for their widget help docs (at one point in the past) and tweaked it from my needs.
