Could mot load data from data source.
3943
12-10-2015 01:37 AM
MohammadBani-Younis
It's three feature classes with related table ,
And i used collector to add new data , then sync the web map with arc map.
there was no problem with feature class attribute , the problem in related table.
did anybody receive thiss error before?
DanPatterson_Retired
From your previous post could not load data from data source   the file loads fine, but there is an issue with the related tables, and the error suggests that it is a particular field and guessing you are using collector, it is with the global id field and from this blog they give some background
Related Tables – Exploring New Ways to use Collector for ArcGIS | ArcGIS Blog
so does any of this apply?
Some related links to Collector...
Collect data—Collector for ArcGIS | ArcGIS
Collector for ArcGIS Place in GeoNet, check out the contents tab
