Create a Dataframe in Arcpy
6704
5
12-09-2015 06:47 AM
StephanieLassieur
I am writing a script which is loading data in various data frames, therefore I need to create Data Frame using python.
I understood there is no straight forward method to do so in Arcpy like addLayer .
However I found this VB dll that is doing a copy paste of a existing data frame.
I don't know how I could call this VB script from my python script and use it...
Duplicate Data Frame (Map) Utility
Any idea or suggestion is very welcome
Thank you in advance
DanPatterson_Retired
Why not create a template mxd which contains a couple of dataframes which you can use .  You may not be able to create a dataframe, but there is nothing to stop you from using a template project...It does work and you can save it to a new one
MapDocument—Help | ArcGIS for Desktop
StephanieLassieur
Thank you for the reply, unfortunately I do need to have at the end of the process one mxd with as many dataframes as layers.
If I would create a template manually with many dataframes I would need to remove the empty ones, which is not possible in arcpy as far as I know
Any other idea?
DarrenWiens2
Rather than delete your unused data frames, move them off the page (elementPositionX and elementPositionY).
As for implementing ArcObjects through Python, it is somewhat difficult to get set up, but it can be done.
FreddieGibson
Honored Contributor
I don't remember there being a method available that would allow you to delete a dataframe. If someone has come across a method that allows this please mention so that I can look into it.
According to my understanding of arcpy, there aren't any methods available for creating content, such as Map Documents, Data Frames, Layout Elements, etc. I've seen most users leverage the workflow noted by Darren Wiens​. Typically they create a map with all of the content they'd require manually and use arcpy to manipulate content. For items like data frames and layout elements the approach is usually to move those items off the screen until they're needed.
If you want to easily accomplish this task you'd want to leverage ArcObjects via .NET or Java. The python approach is possible, but you won't find any supported channels from esri that would show you this approach. If I had to execute this task I would write up a console application or gp tool in ArcObjects. I could execute either of these items from python without too much trouble to create the needed content and them leverage arcpy to further manipulate the content.
Do you have anyone available within your organization that is familiar with ArcObjects?
Since there is no reference to creating a map, I would presume that moving elements off the layout isn't necessary.
There are also no capabilities in the new arcpy.ma module either Introduction to arcpy.mp—ArcPy | ArcGIS for Desktop
except for the ability to import other *.mxd files to create a 'map' which potentially means you could create a template project and import it in a couple of times, if having a couple of dataframes languishing around empty is too much.  Of course, there is the ArcObjects route.  Perhaps the new *.aprx files will follow in their grandparents path and allow for the creation of all kinds of useful objects using python rather than Avenue....time will tell
