CopyFeatures_management from a Python script returns empty layer
4269
12-07-2015 04:44 PM
natashaGregory-Michelman
I am still very new at Python scripting within ArcGIS and I have a script that clips a shapefile to a new AOI, then writes a field to it and updates it with an Update Cursor. I have been successful in using the script up until the CopyFeatures_management part. The script returns a code 0 and has added the new field and has created the correct named shapefile but the file is empty.
Any help would be welcome.
import arcpy
# set local variables
arcpy.env.workspace = "C:/Final Project/GIS"
fc = "settlement_dd.shp"
clip_fc = "AOI.shp"
out_fc = "Settlement.shp"
xy_t = ""
fields = ["Name", "Type", "Model"]
# set attribute table and new fc variables
toModel = "YES"
notModel = "No"
modelFC = "Model"
try:
    # clip point features
    arcpy.Clip_analysis(fc, clip_fc, out_fc, xy_t)
    # add a field called "Model" to the fc
    arcpy.AddField_management(out_fc, "Model", "Text")
except:
    arcpy.AddError("Could not Complete Clip and AddField")
try:
    # create updateCursor and go through rows making the changes to the "Name" field first
    with arcpy.da.UpdateCursor(out_fc,(fields)) as cursor:
        for row in cursor:
            #  update "Name" field with Boma, Building, or TBD
            if row[1] == "Huts 1-2" or row[1] == "Huts 3-5" or row[1] == "Livestock Enclosure":
                row[0] = "Boma"
            elif row[1] == "Buildings 1-2" or row[1] == "Buildings 3-5":
                row [0] = "Buildings"
            elif row[1] == "Settlement":
                row[0] = "TBD"
            # update "Model" field with Yes or NO
            if row[0] == "Boma" or row[0] == "TBD":
                row[2] = "notModel"
            elif row[0] == "Buildings":
                row[2] = "toModel"
            cursor.updateRow(row)
except:
    arcpy.AddError("Could not update rows")
try:
    # make feature layer from points
    pointsQuery = ' "Model" = ' + "'" + toModel + " ' "
    arcpy.MakeFeatureLayer_management(out_fc, "settlement_lyr", pointsQuery)
    arcpy.CopyFeatures_management("settlement_lyr", pointsQuery, modelFC + ".shp")
except:
    arcpy.AddError("Copy Features Unsuccessful")
finally:
    arcpy.Delete_management("settlement_lyr")
DanPatterson_Retired
first step... did you check that the extents overlap...not visually but by examining the extents in the properties of each of the shapefiles
(ps, removed extraneous lines from code to make it easier to read)
PPS
you should really dump those long convoluted if this if that if the other thing, and check whether something is IN something else...
for example
>>> a = "some stuff"
>>> options = ["nope","yup","some stuff"]
>>> if a in options: print("found {}".format(a))
found some stuff
And you need to ensure you have a case where something isn't found which I am not sure you have in those nested loope.
PPS
for example
>>> a = "some stuff"
found some stuff
Dan you are correct that I was not looking properly into whether the original shapefile was correctly noted in the attribute table but I think the main thing was that I was incorrectly using quotation's around the variables that were to update the table within the updateCursor.
I manually corrected the original file and was able to execute the script with your direction. I'm hoping to be able to do this with python in the future.
  Thankyou so much. I really mean it.
I'm working on the convolution of the if elif statements.
   I see now what you're saying
