find duplicates
4133
12-07-2015 02:36 PM
BenButterfield
hi, there.  trying to find duplicate field values in a point class.  my current script just flags the first dup it finds (from 1 - X by OID) with a '1'.  i'd like to take it to another level by only flagging duplicates in specific coded domains.  So if i have three domain values:  x, y, and z I'd like to flag only duplicates found in domains y and z while preserving records with domain values of x.  hope that makes sense.
thanks!
FreddieGibson
Honored Contributor
Can you upload an example of what you've written so far? There would be a number of ways you could implement the logic needed for this and we'd need to see how you beginning this task to give you an appropriate response.
BenButterfield
my apologies.  yes, here is my current script:
uniqueList = []
def isDuplicate(inValue):
  if inValue in uniqueList:
    return 1
  else:
    uniqueList.append(inValue)
    return 0
__esri_field_calculator_splitter__
isDuplicate(!fieldx!)
I'd like to flag duplicates for this scenario:
Field:      Y            X          Flag
               alpha      222
               alpha      333
               beta        222       1
               charlie     222       1
               charlie     333       1
so only duplicates that are NOT alpha will get flagged.
BruceHarold
Esri Frequent Contributor
Please try the Summary Statistics geoprocessing tool with COUNT statistic and domain as case field.
FreddieGibson
Honored Contributor
uniqueList = []
def isDuplicate(value1, value2, skipValue="alpha"):
    if value1 == skipValue:
        return
    if value2 in uniqueList:
        return 1
    else:
        uniqueList.append(value2)
        return 0
you can tweak the above function until you get it the way you want.
