arcpy.da.InsertCursor breaks after 1000 records
6241
9
12-02-2015 12:44 AM
AndreV
Hi, I have a Pythonscript which transforms input featureclass and tables into several output tables and one featureclass. The output tables are connected to the featureclass and to each other with relationship classes (everything in one single GDB). For avoiding nested loops, i initially put the input data into pythonic lists ("data" in the code). I use ArcGIS 10.3.1, Python 2.7.8, here's the code (nothing special):
def insertRows(workspace, fields, data):
    edit.startOperation()
    with arcpy.da.InsertCursor(workspace, fields) as cursor:
        for row in data:
            try:
                cursor.insertRow(row)
            except:
                err = ""
                for elm in row:
                    err = err + str(elm) + "|"
                arcpy.AddError("Error at row: " + err)
                arcpy.AddError(sys.exc_info()[0])
    edit.stopOperation()
Stacktrace:
  File "XX.py", line 600, in <module>
    insertRows(xGDB + os.sep + "BP_Plan", fields_BP_Plan, dict_BP_Plan)
  File "XX.py", line 255, in insertRows
RuntimeError: Feld kann nicht bearbeitet werden. # Field is not editable
Filling the tables with more than 8000 rows is no problem, but the code breaks exactly on inserting record #1000 into output featureclass. The row data itself has no problem (when I switch inputdata's OID sort direction, it also breaks on record #1000). The list objects are also filled. Maybe there are some known limitations on editsessions when many relationship classes are involved.
I would appreciate any hints.
gdi-hohenlohekreis.de
AndreV
hi, I just solved the problem by using the with statement before calling the function insertRows:
    #edit.startOperation()
        for row in data:
    del row
    del cursor
    #edit.stopOperation()
with arcpy.da.Editor(GDB) as edit:
    insertRows(GDB + os.sep + "fc1", fields_fc1, data_fc1)
    insertRows(GDB + os.sep + "table1", fields_table1, data_table1)
    insertRows(GDB + os.sep + "table2", fields_table2, data_table2)
it seems, that the construct with startEditing/startOperation is only working up to 1000 records.
Thanks for your help anyway
NeilAyres
Is the edit object being passed to this function as well?
AndreV
thanks for your hint but it's global
LukeSturtevant
This appears to be a limit for geodatabase tables. I just generated a geodatabase table and tried to insert 2000 random rows and it stopped at 1000, but when I did the same insert cursor on a dBase table not in a geodatabase all 2000 rows were inserted.
AndreV
        for row in data:
    del row
    del cursor
BlakeTerhune
MVP Frequent Contributor
You can probably get rid of the del cursor line because it's redundant with the with statement. The cursor will be deleted automatically when the with statement is exited; same with row.
AndreV
thanks, you are right del statements are needless when using with statement
NeilAyres
I am sorry but I don't believe this explanation.
Inserts inside of an edit operation work for me.
Just did a test and added 10,000 rows. It could have been 10 million.
There is something else going on here.
AndreV
I don't know exactly if that's the crux, but it worked for me. Which version of ArcGIS / Python do you use?
NeilAyres
I am on 10.3.1 & python 2.7.8
