Is it possible to convert to a network aware shapefile?
1900
11-18-2010 12:05 PM
AaronSchuck
I have line data that I want to start using as a network.  I know when you first create a shapefile, you can make it so that your linework will have M values which allow you to store route data.
Does anyone know if there's a way to convert a line shapefile that didn't start out with M values, into one that does have M values?
DonovanCameron
I wonder if you could use the Feature Class to Feature Class tool, and in the environment settings enable the Output has M Values parameter.
Let me know if that works.
JaySandhu
If your goal is to use the lines for network analysis such as shortest path finding, etc, then you do not need to have M values on your line data. For network analysis, you need to make a network dataset from the lines for further analysis with the Network Analyst extension. If your goal is to do utility type work such as upstream/downstream tracing, then you need to create a geometric network and use the Utility Network Analysis toolbar.
The M values are needed for linear referencing/dynamic segmentation type work. You can use the GP tools such as Create Routes or Calibrate Routes to convert lines without M into lines with M.
Regards,
Jay Sandhu
AaronSchuck
My thanks to both of you for your help/suggestions.  The ESRI forums have not disappointed me so far, I've always gotten an answer within a day or two!
