Python script Update Cursor
7239
11-20-2015 12:29 PM
jameljoseph
I have a table in my geodatabase that contains fields with some values and empty fields.
What I am trying to do is first let the user select the table to use, then add values to 2 fields based on values in another field but I am a beginner with python so I was wondering if someone here knows what is wrong with my script.
Thank you
import arcpy
# Get table parameter
param1 = arcpy.Parameter(
    displayname="Roads")
# Open table to edit
GeoDBLocation = open (param1, 'r+')
Fields["LABEL", "SYMBOL", "SYM_TYPE"]
# Add data
cur = arcpy.UpdateCursor(GeoDBLocation)
For row in cur:
    If row.getvalue("LABEL") == "H":
        row.setvalue("SYMBOL", "3.01")
        row.setvalue("SYM_TYPE", "S")
    Elif row.getvalue("LABEL") == "L":
        row.setvalue("SYMBOL", "3.02")
        row.setvalue("SYM_TYPE", "F")
    Else:
        row.setvalue("SYMBOL", "0.01")
        row.setvalue("SYM_TYPE", "O")
    cursor.updateRow(row)
#Delete cursor
del row
del cur
#close file
GeoDBLocation.close
JakeSkinner
Esri Esteemed Contributor
Hi Jamel,
Try using the arcpy.da.UpdateCursor.  It is much faster that the arcpy.UpdateCursor.  Below is an example:
import arcpy
param1 = arcpy.GetParameterAsText(0)
with arcpy.da.UpdateCursor(param1, ["LABEL", "SYMBOL", "SYM_TYPE"]) as cursor:
    for row in cursor:
        if row[0] == "H":
            row[1] = "3.01"
            row[2] = "S"
        elif row[0] == "L":
            row[1] = "3.02"
            row[2] = "F"
        else:
            row[1] = "0.01"
            row[2] = "0"
del cursor
You can then add this script to a toolbox.  You can setup your parameters like the screen shot below to allow users to select a feature class to run the script on:
JakeSkinner
Hi Jamel,
import arcpy
    for row in cursor:
        if row[0] == "H":
            row[1] = "3.01"
            row[2] = "S"
        elif row[0] == "L":
            row[1] = "3.02"
            row[2] = "F"
        else:
            row[1] = "0.01"
            row[2] = "0"
del cursor
jameljoseph
thanks jake, this works as well.  Learnign so much in one day here!
FreddieGibson
Honored Contributor
There are quite a few errors in your code. I've outline them below and also included a copy of what the correct code should look like. I'm assuming that you're writing this for a script tool.
import arcpy
You'd use Parameter if you needed to create one. In this case you need to pull
a value from the tool.
param1 = arcpy.Parameter(displayname="Roads")
open is used to open flat files. This is not going to work with opening a
file geodatabase. The software will handle opening this for you
You're using a variable below called fields and it hasn't been defined. Python
also doesn't support indexing with words.
# Add data
python is a case sensitive languague. The words for, if, elif, and else should
be lowercase. Also, the getValue method needs a capital V.
For row in cur:
    Else:
#Delete cursor
del row
del cur
import arcpy
fields = ["LABEL", "SYMBOL", "SYM_TYPE"]
cur = arcpy.UpdateCursor(param1)
for row in cur:
    value = row.getValue("LABEL")
    if value == "H":
        row.setValue("SYMBOL", 3.01)
        row.setValue("SYM_TYPE", "S")
    elif value == "L":
        row.setValue("SYMBOL", 3.02)
        row.setValue("SYM_TYPE", "F")
    else:
        row.setValue("SYMBOL", 0.01)
        row.setValue("SYM_TYPE", "O")
del row
del cur
jameljoseph
thanks man, it works perfectly.
learning python on the fly but this certainly helps!
