context menus limitations?
3461
11-18-2015 11:37 AM
LefterisKoumis
I noticed that inside the click function of a context menu I don't have access to the map object or call a new function outside the context menu.
Are these limitations for the context menus?
for the script below, I get these errors....
Cannot read property 'addLayer' of undefined
this.myfunction is not a function
ctxMenuForGraphics = new Menu({});
  ctxMenuForGraphics.addChild(new MenuItem(
  label: "something",
  onClick: function ()
   this.map.addLayer(xxx);
   this.myfunction();
  ctxMenuForGraphics.startup();
myfunction: function(){
RobertScheitlin__GISP
Lefteris,
  This works fine:
        var ctxMenuForGraphics = new Menu({});
        ctxMenuForGraphics.addChild(new MenuItem({
          label: "info",
          onClick: lang.hitch(this, function (){
            console.info(this.map);
Lefteris,
  This works fine:
          label: "info",
LefterisKoumis
Thank you.
How do I access the labels assigned for the context menu of a graphic?
I tried ctxMenuForGraphics.MenuItem.label[0] but it doesn't work.
I notice that when you assigned a menu to a graphic A and then a bigger graphic B with its own menu covers graphic A, even if you remove the graphic B later, the menu A will be changed to the one that graphic B had. Strange and I am trying to keep the menu for graphics A unchanged.
Lefteris,
  For the first part of the question:
          label: "info",
          onClick: lang.hitch(this, function (evt){
            console.info(evt.target.innerHTML);
For the second part, I don't have any experience there.
