Script won't run outside of ArcMap
2278
11-18-2015 08:47 AM
MichaelRiccio1
Hello, I am fairly new to Python, but I'm having an issue running a script. It runs fine when I use the python window in ArcMap, but when I try to run the same script either from double clicking a .py file, or running in the IDLE window, I get an error. I know I can easily do this just using select by attributes in ArcMap, but I'm trying to learn more python to automate more things down the road, this is a first test.
The Code:
import arcpy
import os
tree = r"M:\\Temp\ArcPy\Tree.shp"
arcpy.env.overwriteOutput=True
arcpy.MakeFeatureLayer_management(tree, "Tree")
arcpy.SelectLayerByAttribute_management("Tree","NEW_SELECTION",' "Diameter" >=50')
arcpy.CopyFeatures_management ("Tree","Trees50DBH")
arcpy.FeatureClassToFeatureClass_conversion("TreesGreater50DBH",r"M:\\Temp\ArcPy","Tree50DBH")
The Error (happens at the arcpy.CopyFeatures_management code)
  File "M:\Temp\ArcPY\TreeArcPyTest.py", line 12, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 2434, in CopyFeatures
    raise e
ExecuteError: ERROR 000210: Cannot create output Trees50DBH
Failed to execute (CopyFeatures).
I tried searching the various solutions here and elsewhere, but largely they don't apply? Thanks for your help.
Tags (1)
FreddieGibson
Honored Contributor
I'm guessing your problem is with workspaces. In the call to the CopyFeatures tool you're specifying the name of the output class without the directory. Try giving the following a shot. I'm assuming you want to create shapefiles, so I added the extension to the name of the output file. I'd assume in arcmap that everything would output to the default.gdb.
import arcpy
import os
tree = r"M:\Temp\ArcPy\Tree.shp"
arcpy.env.workspace = os.path.dirname(tree)
arcpy.management.MakeFeatureLayer_management(tree, "Tree")
arcpy.SelectLayerByAttribute_management("Tree","NEW_SELECTION",'"Diameter" >=50')
arcpy.CopyFeatures_management ("Tree","Trees50DBH.shp")
arcpy.FeatureClassToFeatureClass_conversion("TreesGreater50DBH", r"M:\Temp\ArcPy","Tree50DBH.shp")
RebeccaStrauch__GISP
you can start by putting an "r" before you path assignment
also, check out Posting Code blocks in the new GeoNet​  for info on posting/formatting your code.  Makes it easier for others to read, and helps with knowing if you space/tabs are lined up.
MichaelRiccio1
Thanks for the formatting tip. I have updated the post.
I also added the r in front of the path assignment, but result is unchanged.
FreddieGibson
Honored Contributor
import arcpy
import os
MichaelRiccio1
Thanks a lot, this has made it work. In the future I'll keep the workspace issue in mind and add any file extensions.
