Duplicate app functionality is failing
4546
11-18-2015 07:37 AM
JoeKilzer
The duplication functionality of the individual apps is failing all of sudden today, anyone having this issue?
RebeccaStrauch__GISP
See if this workaround works for that
Re: Web AppBuilder Developer Edition - Can't create new Apps
Seems like the two issues might be related.  I had the same issue as you at one time, but think I started with a fresh copy....next time I plan to try the workaround.
MajdiTurkman1
I had the same issue. But it works after renaming the app and removing spaces from app name !
HunterCarver
Thanks Majdi,
I renamed, then Duplicate worked, so after duplicating I just changed the name back.  Didn't have any spaces.
