Portal Popups not working... call forced through proxy file.
2989
11-11-2015 10:12 AM
CarlosKrefft
Kinda...So when I "enable Popups" on a layer it will fail. no popups can be displayed. But if I remove the layer, then re-add it, it works fine.
What I'm noticing is that as soon as I click the pull down on the layer, browser throws a SyntaxError: Unexpected token <(…)... when trying to access layer information.
The layer displays fine. The only thing different is the call which errors is being forced through the "..portal/shareing/proxy?.." file. I don't want this and this is probably the reason this is happening. Anyone know how to disable this call from going through the proxy file. None of my services require a proxy file because everything is going through a common reverse proxy and FQDN... ie: server99.domain.com/portal, server99.domain.com/arcgis, etc.
