Custom DynamicLayer (heatmap) / internal constructor
3620
11-09-2015 05:30 AM
Espen_RøvikLarsen
I'm trying to port the WPF heatmap to ArcGIS Runtime for .NET. Sadly the DynamicLayer is not possible to inherit due to an internal constructor.
What would be the best approach to implement a heatmap?
EDIT: No AGS processing - only local realtime
Espen
MichaelBranscomb
Esri Frequent Contributor
Currently the client-side Heatmap layer is not supported because we would like to implement a new high performance heat map layer in the ArcGIS Runtime itself.
One option until then is to use the LocalServer with a geoprocessing task, although that will require a standard license.
Cheers
Mike
JohnKuhn1
When will a client-side heat map be available for .net?  Are there examples using LocalServer to create a heatmap and what will the additional licensing cost be?
dotMorten_esri
Esri Notable Contributor
Update 1 will be able to load heatmap renderers pre-authored in a webmap. However we won't have an API for creating heatmaps until a later release.
MichaelBranscomb
You can use LocalServer to generate heatmaps - it supports the Kernel, Line and Point Density GP tools - for more info see:
Local Server geoprocessing tools support—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
An overview of the Density toolset—Help | ArcGIS Desktop
We don't have a sample showing that specifically, but it's the same process as publishing any geoprocessing model/script for use with Local Server. It would require a Standard license, plus the Analysis extension (License your app—ArcGIS Runtime SDK for .NET | ArcGIS for Developers).
Cheers
Mike
