Is there a way to use the built-in Coordinate System or Spatial Reference dialog picker from an Add-in?
4081
11-06-2015 11:23 AM
JosephMcCausland
I have an add-in where I want to display a dialog to get the desired spatial reference from the user.  In the ArcGIS Desktop .NET SDK I would use ESRI.ArcGIS.CatalogUI.SpatialReferenceDialog.  Does the Pro 1.1 SDK have something similar?
CharlesMacleod
Hi Joseph, I wrote one for you.
Please go to the Pro community samples on the github at https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Geometry/CoordinateSystemDialog
There is no API call currently to get the list of SpatialReferences so I had to use arcpy.ListSpatialReferences.
We will look at adding that capability into the DotNET API for Pro at 1.3
CharlesMacleod
