Shortlist Configuration - Tab-specific Extents
5328
11-05-2015 11:57 AM
deleted-user-pSEFA8qSxLCv
Anyone have a tutorial or sample code to configure tab-specific extents for the shortlist story map? (Example
http://www.esrith.com/apuc/) Thanks
MarkCooney
Hi Jonathan,
The code you need is in the example you pointed to.  This was a custom version we helped Esri Thailand with for the Esri Asia Pacific User Conference.  There are a few changes to the code, including two parameters in the configuration section of the index.html (FILTER_LIST_BY_EXTENT, and tabExtents).  Those parameters are then used in functions called refreshList, and activateLayer, that are both in the main.js file of the app (http://www.esrith.com/apuc/app/js/main.js).
MarkCooney
Hi Jonathan,
