Add layer and scale using python
4475
11-05-2015 02:27 AM
Yaron_YosefCohen
Hi everyone,
I have 14 mxd's with scale 50000 and one mxd with scale 25000. with this code i try to add  a new layer, extent to this layer then set a new scale 500000- just to mxd's with scale 50000 . i doesn't want to change the 25000 scale mxd, but i do want just to add him the new layer - and it doesn't work.
i don't know what wrong with this code- i think i didn't place the "if" statement in the right place:
import arcpy,os,sys
from arcpy import env
env.workspace = r"C:\Project"
lyr1 = arcpy.mapping.Layer(r"D:\PROJECTS\industryArad\gis\layers\4_11_15\GVUL TOHNIT.dwg Polyline.lyr")
for mxdname in arcpy.ListFiles("*.mxd"):
    print mxdname
    mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
    df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
    if df.scale == 25000:
        continue
    arcpy.mapping.AddLayer(df, lyr1, "TOP") # TOP \ BOTTOM \ AUTO_ARRANGE
    print 'AddLayer'
    lyr = arcpy.mapping.ListLayers(mxd, "GVUL TOHNIT.dwg Polyline", df)[0]
    ext = lyr.getExtent()
    df.extent = ext
    print 'getExtent'
    df.scale = 500000
    print df.scale
    for lyr in arcpy.mapping.ListLayers(mxd, "bbb",df):
        arcpy.mapping.RemoveLayer(df, lyr)
        print 'remove'
    mxd.save()
del mxd
DanPatterson_Retired
the logic is
if the scale is 25000
      then do something that only applies to layers of that scale
else: (if it is not 25000)
      do something else that only applies to layers not of 25000 scale
carry on doing stuff that applies to both situations.
the logic is
Yaron_YosefCohen
great it works !!! thanks Dan
    print mxdname
        print 'AddLayer to ' ,mxdname
    else:
        df.extent = ext
        print 'getExtent'
        df.scale = 100000
        print df.scale
        print 'remove'
