DMS to Pro xy?
3198
11-04-2015 11:04 PM
MirbazAhmadzai
How Can I convert DMC to Pro absolute xy, because Pro need xy and our Data in DMC like (30°11'4.46"N)
69.20800481249913, 34.654771721221316
DanPatterson_Retired
DMS to decimal degrees manually in arcmap and Pro or the Convert Coordinate Notation​ tool
MirbazAhmadzai
Type Of xy in Pro?
BillChappell
One issue is DMS is a string and you need to convert it to a number (Double) so you can plot them
The basic conversion is dd = d + m/60 + s/3600
you could field calculate it in ArcMap  two fields  DMS has the dms values, and DD a double field where you want to field calc it
.DD=  left( [DMS],2) + (mid( [DMS],4,2)/60) + (Mid( [DMS], 7,4)/3600)
The left and mid functions are a way to pull apart the string, in your example
30°11'4.46"N  you want the left 2 (maybe 3 if in western hemisphere ie. -30)   Mid 4,2 gets the 11 and mid 7,4 gets the 4.46  The °'."N symbols are not math symbols..
