Display additional attribute details on form ?
3955
11-05-2015 11:21 AM
blainecastle1
Is is possible to add a 'popup' on the form to provide more details for the user about the different attribute values?
For example, an attribute has values SMALL MEDIUM LARGE
     Popup provides context,     MALL < 500
                                                MEDIUM 501 - 1000
                                                LARGE > 1001
Tags (3)
HannahFerrier
You can also use NOTE fields to display information on the form. This is more powerful than just using a hint as you can combine notes that contain pictures,text and audio, as well as HTML formatting to communicate your message.
For more information on NOTE fields, see: Survey123 for ArcGIS support for XLSForm
- Hannah
JakeSkinner
Esri Esteemed Contributor
Hi Blaine,
Would applying a 'hint' work?  Ex:
blainecastle1
Hi Jake
That would probably do it
I was previously working with FilemakerPro and was thinking of the ability to add notes to form that provide similar functionality as a popup on the side of the form
Cheers
Blaine
HannahFerrier
- Hannah
blainecastle1
Thanks Hannah - the NOTE field looks like it is exactly what I’m looking for!
The ability to add more than just photos & text is great!
