Problem replicating Grouping Analysis 'grouping effectiveness' statistic results
4626
7
11-04-2015 03:08 AM
AndrewLowerre
Dear All,
I have been using the Grouping Analysis tool to generate a range of clusters from my data. I'm using ArcGIS v10.2.1. I wrote a Python script to run Grouping Analysis a large number of times (with different clustering algorithms and spatial constraints and with the number of clusters (k) ranging from 3 to 250) and report the 'grouping effectiveness' statistic (the Calinski-Harabasz pseudo-F statistic: see ArcGIS Help (10.2, 10.2.1, and 10.2.2), or CH Index for short ) so I can try to identify the 'best' number(s) of clusters for my data. This has all been working fine.
To compare these results with some from additional clustering methods, I have also used another application (REDCAP: Regionalization with Constrained Clustering and Partitioning | Spatial Data Mining and Visua... ) on my data as well. Fantastic though the software is, REDCAP does not report the CH Index to help evaluate the 'best' number of clusters in the data. I would like to be able to compare/evaluate my results from ArcGIS's Grouping Analysis with those from REDCAP using the same 'grouping effectiveness' statistic, so I have written another Python script to try to calculate the CH Index 'by hand', as it were, and this is where I've run into a problem.
I wrote my script to try to replicate the approach set out in the Help file for 'How Grouping Analysis works' (ArcGIS Help (10.2, 10.2.1, and 10.2.2)) and in the Python script the tool calls (Partition.py). I tried out my script on some of my output feature classes from Grouping Analysis, to check that my script was producing the same results. Here (finally) is the problem: when the Grouping Analysis was based on a single variable, I get exactly the same CH Index result from my script as from Esri's own tool; when the Grouping Analysis was based on more than one variable, I get a different (higher) CH Index result from my script. I am stumped as to why this is happening.
This is my code:
# Get and print the starting time for running the script
import datetime
start_time = datetime.datetime.now()
print("Script started at " +str(start_time))
import arcpy
import numpy as np
arcpy.env.workspace = r"E:\Pr6653_GIS_Data_Maps\SKATER_ClusterOutputs_1021FGDB.gdb"
# The input feature class
inFC = "Clstrs_DstNcl_All_DSHC_RC_K9"
# The fields used to generate the clusters using Grouping Analysis
inFields = ["DstNcl_All_SCL01INV", "DSInterp_SCL01INV", "HCInterp_SCL01INV"]
# The field holding the values identifying the clusters
clstField = "SS_GROUP"
# Create a new list from inFields and add the cluster field, to be used when
#     creating the structured Numpy array from the input FC table
arrFields = list(inFields)
arrFields.append(clstField)
# Convert the attribute table of the input FC to a NumPy array
baseArr = arcpy.da.TableToNumPyArray(inFC, arrFields)
n = len(baseArr) # This is the number of features in the input FC
# Get values based on the clustering field
clstArr = np.unique(baseArr[clstField])
nc = len(clstArr) # This is the number of groups
nc_min = clstArr.min() # This is the minimum value for cluster ID
nc_max = clstArr.max() # This is the maximum value for cluster ID
SST = 0.0 # This is the total sum of squared differences
for fld in inFields: # For each field/variable...
    varMean = baseArr[fld].mean() # Get the overall mean for the variable
    varSS = ((baseArr[fld] - varMean)**2.0).sum() # Calculate the sum of squared differences from the variable mean for each value
    SST += varSS # Add that sum to the total sum of squared differences
SSE = 0.0 # This is the sum of squared differences within each group
for group in range(nc_min, nc_max + 1): # For each group...
    grpArr = baseArr[baseArr[clstField] == group] # Create a new array just for that group
        grpMean = grpArr[fld].mean() # Get the mean for the variable in that group
        grpSS = ((grpArr[fld] - grpMean)**2.0).sum() # Calculate the sum of squared differences from the group mean for each value in the group
        SSE += grpSS # Add that sum to the within-group sum of squared differences
# Calculate the pseudo-F statistic
R2 = (SST - SSE) / SST
fStat = (R2 / (nc - 1)) / ((1 - R2) / (n - nc))
# Print the results
print("For input " + inFC + ":")
print("Number of features = " + str(n))
print("Number of clusters = " + str(nc))
print("SST = " + str(SST))
print("SSE = " + str(SSE))
print("R2 = " + str(R2))
print("CH Index = " + str(fStat))
# Clean up
del baseArr, grpArr, clstArr
del n, nc, nc_max, nc_min
del SST, SSE, R2, fStat
del inFields, arrFields
print("Script complete. Elapsed time: " + str(datetime.datetime.now() - start_time))
# End of script
If it would help, I'd be happy to post some example data as well.
If anyone has any ideas, I'd be very grateful. Like I said, this code seems to work fine in a univariate situation, but not in a multivariate situation. I should also point out that I don't have a strong background in either statistics or programming, so I may just be missing something blindly obvious!
Many thanks in advance,
Andrew
Message was edited by: Andrew Lowerre Just cleaning up some copy-and-paste issues in the code I posted. Should now all be correct!
AndrewLowerre
OK, I figured out the problem: I needed to standardise the values in each of the input fields to z-scores (subtract the mean and divide by the standard deviation).
My new code is as follows:
import datetime
import arcpy
import numpy as np
def zScore(inTable, inFld, outFld):
    """Calculate z-scores for values in one field and write them to another field"""
    fldArr = arcpy.da.TableToNumPyArray(inTable, inFld)
    fldMean = fldArr[inFld].mean()
    fldStdDev = fldArr[inFld].std()
    with arcpy.da.UpdateCursor(inTable, [inFld, outFld]) as cur:
            for x, y in cur:
                y = (float(x) - fldMean)/fldStdDev
                cur.updateRow([x,y])
    del fldArr
    del fldMean, fldStdDev
# inFC = "Clstrs_DstABCDE_DSHC_QC_K36"
# inFields = ["DstNcl_A_SCL01INV", "DstNcl_B_SCL01INV", "DstNcl_C_SCL01INV", "DstNcl_D_SCL01INV", "DstNcl_E_SCL01INV", "DSInterp_SCL01INV", "HCInterp_SCL01INV"]
arrFields = []
# Copy input dataset into memory
print("Copying source features into memory")
arcpy.CopyFeatures_management(inFC, "in_memory\\inMemSrcCopy")
# Add and populate fields for z-Scores
print("Adding and populating z-score fields for in-memory FC")
    arcpy.AddField_management("in_memory\\inMemSrcCopy", fld + "_Z", "DOUBLE")
    zScore("in_memory\\inMemSrcCopy", fld, fld + "_Z")
    arrFields.append(fld + "_Z")
# Convert the attribute table of the in-memory input FC to a Numpy array
baseArr = arcpy.da.TableToNumPyArray("in_memory\\inMemSrcCopy", arrFields)
print("Calculating the total sum of squared differences")
        fld = fld + "_Z"
        varSS = ((grpArr[fld] - varMean)**2.0).sum() # Calculate the sum of squared differences from the variable mean for each value in the group
print("Calculating the sum of squared differences within each group")
##lstSSE = []
# for group in range(nc): # For each group...
        fld = fld + "_Z"
        grpMean = (grpArr[fld]).mean() # Get the mean for the variable in that group
print("\tNumber of features = " + str(n))
print("\tNumber of clusters = " + str(nc))
print("\tSST = " + str(SST))
print("\tSSE = " + str(SSE))
print("\tR2 = " + str(R2))
print("\tCH Index = " + str(fStat))
arcpy.Delete_management("in_memory")
# End of script
This revised code produces results identical to those reported by Esri's tool.
Problem solved.
DanPatterson_Retired
Two thoughts come to mind since you don't report the difference in statistics values
  • whenever statistics test from other sources report a value that contains the std deviation or variance, I always check to see whether they are using population or sample representations (ie division by N or N-1 in the reducing term)
  • whenever division is employed, I always ensure that at least one term in the calculation is floating point to ensure floating point division rather than integer division (being a function of python version etc)
So if you can report your difference values in the context above, it may help to further delineate the issue
AndrewLowerre
Hi Dan,
Many thanks for the quick reply.
OK, for the dataset referenced in my code above, the CH Index as reported by Esri Grouping Analysis is 1911.75679228486. The CH Index value reported by my script is 2448.47996865.
For a different dataset (same input fields as in my code, but with 31 clusters), the results are as follows:
CH Index from Esri tool: 1069.1115254454
CH Index from my script: 1114.27024452
I just tried addressing the possible integer division problem you mention, so I changed line 23 to
n = len(baseArr) * 1.0
and line 27 to
nc = len(clstArr) * 1.0
and it made no difference in my results
I also tried changing the reducing term to N - 1, so changing line 47 in my code to
fStat = (R2 / (nc - 1.0)) / ((1.0 - R2) / ((n - 1.0) - nc)) )
This also has a negligible effect. The CH Index for the dataset referenced in the original code I posted is now 2448.40544257.
So, still stumped.
So basically you are saying that you now account for the use of samples in the CH statistics formula​ and it is now worse? or have you double corrected...just checking
AndrewLowerre
Assuming I understand you correctly, I've accounted for the use of samples and the result is now very, very slightly better, but only very slightly:
CH Index from Esri tool: 1911.75679228486
CH Index from my script (not accounting for using samples): 2448.47996865
CH Index from my script (accounting for using samples): 2448.40544257
Not much difference in my results, and both are a long way off from what Esri's tool reports.
I guess I am missing whether R2 is similar or way off since fstat and CH depend upon it.  Assuming options are consistent between the two and you are working with projected data since this will have an impact on the grouping methods that employ distance or enclosure. And I also assume that your SSE and SST calculation methods are correct.
AndrewLowerre
Hi Dan,
I suspect the issue probably is that the way I've calculated SSE and SST are not correct (or at least not correct for a multivariate situation), but I can't figure out how or why.
The issue won't be with projected vs unprojected input data. To be clear, the dataset I'm using as an input to my script is one that was output from the Grouping Analysis tool. And I was definitely using projected data as input to the Grouping Analysis tool.
When I use a different dataset as an input to my script (again, a dataset that was output from the Grouping Analysis tool), where I created the clusters using only one input field, the results are as follows:
CH Index from Esri tool: 6349.09734505356
CH Index from my script (not accounting for using samples): 6349.09734505
CH Index from my script (accounting for using samples): 6348.90412258
So when I have a univariate input, my script (not accounting for using samples) replicates exactly the results from Esri's tool (well, to 8 decimal places, which is good enough for me). And when I have a univariate input, accounting for using samples gives a result that is different from Esri's tool.
What I'm trying to do is check that I can replicate the CH Index value that the Grouping Analysis tool produces using my own script, so that I can be sure that I've got the calculations correct. As far as I can tell, my calculations are correct when I'm calculating SSE and SST for a single input variable, but they are not correct when I calculate SSE and SST for more than one input variable. That's where I'm stumped.
AndrewLowerre
import datetime
import arcpy
import numpy as np
            for x, y in cur:
    del fldArr
arrFields = []
        fld = fld + "_Z"
##lstSSE = []
        fld = fld + "_Z"
# End of script
Problem solved.
