widget with no icon or UI
2732
10-29-2015 12:56 PM
LefterisKoumis
I created a off-panel widget that it has no UI and it opens at start-up. It performs some initial tasks, like reading the URL parameters and it acts accordingly.
I don't need the widget icon to be displayed anywhere on the map. Is there an easy way to do without an icon?
Thanks.
RobertScheitlin__GISP
Lefteris,
   Sure you can use the Splash or Scalebar widget as an example
RickeyFight
Lefteris,
I believe the local layer widget does not have an icon. I would look at that code for tips on how to do this.
LocalLayerWidget and AccessifizrWidget
LefterisKoumis
Thank you Ricky. I looked up at the LocalLayerWidget and it was not straightforward of how to do it. Then, I looked at the Splash Widget, per Robert's suggestion, and voila, it was right at the first block of the css code.
Lefteris,
