Parameters in Python script
6805
10
10-29-2015 07:22 AM
TerryGustafson
I'm trying to figure out parameters in python.  I created a model and it has some parameters in it.  When I run it and create a GP service from it, it asks me to enter those parameters and then runs.  I have a python script that I added to a toolbox hoping it would ask for those parameters as well.  when I add the script to the toolbox and run it, it says this tool has no parameters.  I assumed the in the script arguments from my example that the first_point = arcpy.GetParametersAsText(0) would ask me to enter the first point.  Can someone point me in the right direction?  TIA
# -*- coding: utf-8 -*-
# new_seg4.py
# Created on: 2015-10-29 07:32:00.00000
#   (generated by ArcGIS/ModelBuilder)
# Usage: new_seg4 <first_point> <end_point> <first_point__2_> <end_point__3_> <beg_point> <end_pt> <first_pt_loc> <end_pt_loc> <points> <segment> <temp__2_>
# Description:
# Import arcpy module
import arcpy
toolbox = ("E:/MDTAPPS/interactive/refmseg.tbx")
# Load required toolboxes
arcpy.ImportToolbox("E:/MDTAPPS/interactive/refmseg.tbx")
# Script arguments
first_point = arcpy.GetParameterAsText(0)
if first_point == '#' or not first_point:
    first_point = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_point" # provide a default value if unspecified
end_point = arcpy.GetParameterAsText(1)
if end_point == '#' or not end_point:
    end_point = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_point" # provide a default value if unspecified
first_point__2_ = arcpy.GetParameterAsText(2)
if first_point__2_ == '#' or not first_point__2_:
    first_point__2_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_point" # provide a default value if unspecified
end_point__3_ = arcpy.GetParameterAsText(3)
if end_point__3_ == '#' or not end_point__3_:
    end_point__3_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_point" # provide a default value if unspecified
beg_point = arcpy.GetParameterAsText(4)
if beg_point == '#' or not beg_point:
    beg_point = "beg_point" # provide a default value if unspecified
end_pt = arcpy.GetParameterAsText(5)
if end_pt == '#' or not end_pt:
    end_pt = "end_pt" # provide a default value if unspecified
first_pt_loc = arcpy.GetParameterAsText(6)
if first_pt_loc == '#' or not first_pt_loc:
    first_pt_loc = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc" # provide a default value if unspecified
end_pt_loc = arcpy.GetParameterAsText(7)
if end_pt_loc == '#' or not end_pt_loc:
    end_pt_loc = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc" # provide a default value if unspecified
points = arcpy.GetParameterAsText(8)
if points == '#' or not points:
    points = "E:\\MDTAPPS\\interactive\\interactive.mdb\\points" # provide a default value if unspecified
segment = arcpy.GetParameterAsText(9)
if segment == '#' or not segment:
    segment = "segment" # provide a default value if unspecified
temp__2_ = arcpy.GetParameterAsText(10)
if temp__2_ == '#' or not temp__2_:
    temp__2_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\temp" # provide a default value if unspecified
# Local variables:
Output_Event_Table_Properties = "RID POINT MEAS"
Output_Event_Table_Properties__2_ = "RID POINT MEAS"
MDTGIS_ROUTES_LRM_RM = "MDTGIS.ROUTES_LRM_RM"
MDTGIS_ROUTES_LRM_DC_MI = "MDTGIS.ROUTES_LRM_DC_MI"
MDTGIS_ROUTES_LRM_DC_MI__2_ = "MDTGIS.ROUTES_LRM_DC_MI"
interactive_mdb = "E:\\MDTAPPS\\interactive\\interactive.mdb"
MDTGIS_ROUTES_LRM_DC = "MDTGIS_ROUTES_LRM_DC"
temp = "E:\\MDTAPPS\\interactive\\interactive.mdb\\temp"
# Process: Calculate Field
arcpy.CalculateField_management(first_point, "Corridor", "str(!Corridor!) + \"_\" + str(!RM!)", "PYTHON_9.3", "")
# Process: Calculate Field (2)
arcpy.CalculateField_management(end_point, "Corridor", "str(!Corridor!) + \"_\" + str(!RM!)", "PYTHON_9.3", "")
# Process: Make Route Event Layer (2)
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_RM, "ROUTE_ID", end_point__3_, "Corridor POINT end_offset", end_pt, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_RM, "ROUTE_ID", first_point__2_, "Corridor POINT beg_offset", beg_point, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
# Process: Locate Features Along Routes
arcpy.LocateFeaturesAlongRoutes_lr(beg_point, MDTGIS_ROUTES_LRM_DC_MI, "CORRIDOR", "0 Meters", first_pt_loc, Output_Event_Table_Properties, "ALL", "NO_DISTANCE", "ZERO", "NO_FIELDS", "NO_M_DIRECTION")
# Process: Locate Features Along Routes (2)
arcpy.LocateFeaturesAlongRoutes_lr(end_pt, MDTGIS_ROUTES_LRM_DC_MI__2_, "CORRIDOR", "0 Meters", end_pt_loc, Output_Event_Table_Properties__2_, "FIRST", "NO_DISTANCE", "ZERO", "NO_FIELDS", "NO_M_DIRECTION")
# Process: Append
arcpy.Append_management("E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc;E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc", temp, "", "RID \"CORRIDOR\" true true false 10 Text 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc,RID,-1,-1,E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc,RID,-1,-1;beg_offset \"beg_offset\" true true false 8 Double 0 0 ,First,#;end_offset \"end_offset\" true true false 8 Double 0 0 ,First,#", "")
# Process: Table to Table
arcpy.TableToTable_conversion(temp__2_, interactive_mdb, "points", "", "RID \"CORRIDOR\" true true false 10 Text 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,RID,-1,-1;beg_offset \"beg_offset\" true true false 8 Double 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,beg_offset,-1,-1;end_offset \"end_offset\" true true false 8 Double 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,end_offset,-1,-1", "")
# Process: Make Route Event Layer (3)
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_DC, "CORRIDOR", points, "rid LINE beg_offset end_offset", segment, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
# Process: Script1
arcpy.Script1_ref()
JamesCrandall
You must add the parameters to the Toolbox script.  Right-click the Toolbox script and open the Properties dialog to find the Parameters tab.
TerryGustafson
That is exactly what I was looking for.. My first_point is a table so would the data type be table for the parameter?
JamesCrandall
From your example code it looks like you are just passing in the path to the table, so... maybe the parameter should just be a string type?
TerryGustafson
My end goal it to add this service to a WAB widget and have the user enter the information from the widget and then it passes the data to the service..
TerryGustafson
I spoke to soon, I thought I could set those parameters once the GP service was created. If I set them in the script before I run it to publish it, it crashes.. I set them to string..
File "C:\Users\U0654\Desktop\new_seg4.py", line 29, in
File "E:\MDTAPPS\Desktop10.2\arcpy\arcpy\__init__.py", line 632, in GetParameterAsText
return gp.getParameterAsText(index)
File "E:\MDTAPPS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 224, in getParameterAsText
self._gp.GetParameterAsText(*gp_fixargs(args, True)))
RuntimeError: Object: Error in getting parameter as text
JamesCrandall
Did you set a parameter for  first_point__2_?
TerryGustafson
thanks for your help, I have been struggling learning this..  I did look at the parameters in the model and it gave me an example so going to try this..
TerryGustafson
I don't know if its going to work as the only reason I made some of those parameters was to get the model to export the variables correctly so it would run.  when I run it through the model with only the first_point and the end_point as parameters and generate the GP service and run it this is the dialog that shows..
TerryGustafson
I’m thinking the segment would have an output parameter? So the direction would be output? In the parameter properties?
