Re: Joining values of two fields
3796
7
10-09-2015 07:05 AM
TerryGustafson
Thanks that worked great..  I know I should post this in a new thread but was hoping for a quick answer.  I'm trying to join 2 fields.  the corridor field and the RM field.  I was thinking it would look something like this but cant seem to figure it out.  .join(!Corridor! + !RM!)
JakeSkinner
Esri Esteemed Contributor
You can perform this in the field calculator.  Make sure you have 'Python' at the top of the field calculator checked and then the syntax would be:
!Corridor! + !RM!
TerryGustafson
I tried that and it won’t work.. Not sure if it has something to do with it being a text field..
JakeSkinner
If you are calculating into a TEXT field, and on of the fields is an integer, try the following:
str(!Corridor!) + str(!RM!)
If not, let me know what type of fields Corridor, RM, and the field you are calculating to are.
DanPatterson_Retired
Or try this tip
TerryGustafson
That worked but it adds a .0 to the end of the RM..  I created the RM field as a short with 0 decimal places.  So it returned C000001E156.0.  The precision is set to 4
TerryGustafson
I got it..  Thanks for your help./.  Have a good weekend..
curtvprice
I'm trying to join 2 fields.  the corridor field and the RM field. Calculate Field (PYTHON) str(!CORRIDOR!) + str(!RM!) worked but it adds a .0 to the end of the RM..  I created the RM field as a short with 0 decimal places.  So it returned C000001E156.0.  The precision is set to 4
Try this Calculate Field syntax
arcpy.CalculateField_management(tbl, field,
    "{}{:.0f}".format(!CORRIDOR!, !RM!), "", "PYTHON_9.3")
